Help please!
Old Sep 10, 2011 | 01:21 PM
Fordmad!'s Avatar
Fordmad!
Default Help please!
Changed the radiator on my xr3i (efi) this morning was running fine!
Started her up now and it only just started and it was spluttering and had to keep reving it to keep it running. Turned it off now it won't start!
Took the plugs out and they are black! Gave them a clean and still no luck!!!
Noticed the 4th plug has very slightly bent, what could course this?
Help please
Old Sep 10, 2011 | 01:59 PM
Fordmad!'s Avatar
Fordmad!
Anyone?
Old Sep 11, 2011 | 02:33 PM
Fordmad!'s Avatar
Fordmad!
Old Sep 11, 2011 | 05:26 PM
Fordmad!'s Avatar
Fordmad!
Need some help please!
Old Sep 11, 2011 | 06:04 PM
Icurus's Avatar
Icurus
I take it you have changed the bent plug for a good one?
Are you getting a spark on each plug? Have you tested this?
Did you dis-connect any wiring before taking out the rad?
Have you checked that you have not dislodged anything?
Does this engine have a dizzy? If yes, has it moved position? Is the cap ok?
Old Sep 12, 2011 | 06:37 AM
Fordmad!'s Avatar
Fordmad!
Need new plugs.
Have checked can't see any problems.
It did run for a short while after.
No dizzy its efi
