Setting up Engine Setting for flatshift??
Old Sep 10, 2011 | 09:32 AM
boXXer's Avatar
boXXer
GASH!
Default Setting up Engine Setting for flatshift??
Setting up Engine Setting for flatshift???
Can anyone help me with the setup of my geartronics flatshift system on my emerald ecu?
I dont know what to set the ignition settings too and how they effect the running of the motor. Its currently set a 0* BTDC but dont know whether to advance or retard it?
Also, On emerald ECU's, they have the option of a "1k pull up resistor" on the input pin settings. What does this do, and how would i use it on a Earth switched ignition cut?
Cheers all
Old Sep 10, 2011 | 10:47 AM
Icurus's Avatar
Icurus
Might be an idea to ring Emerald in regards to this? Dave Walker is usually very helpful
Do you have the K3 manual?
Old Sep 10, 2011 | 12:11 PM
Rick's Avatar
Rick
The pull up resistor is tied to 12v so the input isn't floating when the switch isn't connected. So 12v to resistor, other end of resistor to ecu input and also to clutch switch. Other end of clutch switch to ground. Switch needs to make contact when clutch is pressed.
Old Sep 10, 2011 | 12:19 PM
boXXer's Avatar
boXXer
GASH!
I don't have a clutch switch as the geartronics ecu sends a earth to the input on the emerald ecu so is basically the switch itself.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
