fitting a chip in cosworth ecu
just got my stage 1 chip to go in my 2wd cozzy but never changed one on a cozzy before so where is the ecu and how do i get it out?
also anyone have a pic of what chip i need to take out?
changed the chip in my old 325 e30 and this chip seems to fit same as the bmw one.
As said, there are four screws holding the cover on and you will need to remove two screws to actually remove it to start with, they can be a bit awkward to get in/out.
The chip may well be the same but the software is obviously completely different, old BIOS chips aren't dissimilar either.
It will be obvious once you see the ECU as the chip will only fit in it's correct location.
Martin
Martin
right just opened it up and its got a big yellow label over the chip saying L6STAGE1.
must of just had the boost turned down?
wonder if its worth putting this turbosystems chip in?
its all wired up so am guessing it works. the car is only running 10 psi so i think the boost may have been turned down.
anyway fitted the chip adjusted the actuator a tiny bit and started it up.
seems to idle a bit higher now and is a tiny bit of smoke so it could be running rich?
just going to take it real easy to my mates tommorrow so he can check the co2 out.
just trying to find out what the c02 should be for this chip.
What colour is the smoke?
Last edited by Guinnless; Sep 9, 2011 at 06:29 PM. Reason: Just spotted the chip is from Turbosystems
the c02 was at 3% so just left it there. only hitting 13psi though but am on the standard actuator so may get a -31.
although i keep thinkin of selling and getting a s3 or a evo for some reason.
remove the restrictor from the r port of the amul valve and recheck the boost level
this can be done bt using a small self taper
boost level should be set at around 17 psi spike ,holding 15-16 tailing at 6krpm to 13
fuel pressure should be set to 3.8 bar absolute ie vac off
cheers tony. think am best taking it somewhere to get it setup properly as i dont have the tools or know how.
quick question how much would a decent tuner charge to fit greens,chip, 3 bar map senser and set my car up?
is it safe buying greens second hand?
glenn thats the only thing that has put me off evos is the price of bits.
probs be near christmas time if i put some greens in and get it setup ect just wondering how much its gonna cost to do it properly
That's the best way baz get it done right first time like I did and mine was reliable I used to use it everyday and it never let me down.
I think you will be supprised at how much it will cost it's not that bad.
Ive also heard horror stories about evos too.2 lads i know had them. One lad had a evo 5 and he blew
the bottom end out of the engine.Then another lad i know fooked the cams in his evo 4.
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
lol
