fiesta rs turbo wiring
hello all,
this week i got a fiesta mk3 at my garage which was going to be converted to rs turbo by another mechanic but now he does not want to carry out the job.i accepted to do it but need some help as regards the wiring diagram and where is the ecu located.it is the first one i am doing and being from malta i can t find any help.
thanks in advance to all for your help
adrian
adrian
The ecu is located in the engine bay at the passenger side ( right hand drive ) just under the scuttle panel there is a 10mm bolt on top undo the bolt ad the ecu will drop down into the inside passenger side
paceo
Feb 3, 2016 10:31 AM
Matt Baxter
Sep 16, 2015 08:30 PM
