COLD IDLEING
Old Feb 15, 2005 | 10:04 PM
JaysS2TURBS's Avatar
JaysS2TURBS
Default COLD IDLEING
Which engine component aids the cold idle speed?
My revs drop to low when the engine is started from cold has anyone had this fault before let us know CHEERS
Ive tried adjusting the idle screw but once the engine is running at normal temperature the engine revs to high
Old Feb 15, 2005 | 11:06 PM
S1 Barkham's Avatar
S1 Barkham
You sure it's not a slight boost leak, i had this problem and found i had a small boost leak.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
