is two inches too low!
Old Sep 6, 2011 | 07:44 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default is two inches too low!
I fitted my ford rs mud flaps on my mk4 earlier and they sit 2 inches off the floor so will scrape like fook over speed bumps but look quite cool!
Is 2 inches too low!?
What do you guys think would look better, front and rear or just rear? ?? (I'm in two minds)
Old Sep 6, 2011 | 07:48 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
All around nice and low,massively helps keep car clean too
Old Sep 6, 2011 | 07:51 PM
stuboy's Avatar
stuboy
mine on my old mk4 ghia used to scrape and i didnt bother with it
Old Sep 6, 2011 | 08:03 PM
Jamie_EscortSport
Good dint want em sat too high but also the cars sat down 40-45mm
Old Sep 6, 2011 | 08:05 PM
Ade's Avatar
Ade
Fast Ford snapper
Sounds like your car needs lowered another inch and a half
Old Sep 6, 2011 | 08:09 PM
Jamie_EscortSport
Don't tempt me...at ford fair I got a pic from the bridge n it looked like a monster truck, which luckily sped up me lowerin it in the first place
Old Sep 6, 2011 | 08:31 PM
RSmark84's Avatar
RSmark84
mine sat low. Less than an inch gap between flat ground and mudflap(genuine) no problems scraping on the ground and looked good.
Old Sep 6, 2011 | 08:45 PM
Jamie_EscortSport
yeee mine are fine until i hit a speed bump, or my drive which iv not long found out xD
Old Sep 7, 2011 | 06:13 AM
Byrnes1's Avatar
Byrnes1
2.0 MK6 Escort track slag
I used to have my old fez mudflaps about 2 fingers width from the ground.
Lower the better helps keep shit off the paintwork
Old Sep 7, 2011 | 06:03 PM
Jamie_EscortSport
Love it!
Old Sep 7, 2011 | 08:00 PM
RichieST's Avatar
RichieST
If they are hard plastic ones then they will rip straight off, I found out the hard way
The soft flexible ones should be fine though!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
DavidK
Sep 27, 2015 02:55 PM
Tank Mike
Sep 26, 2015 08:07 AM
