No spark on an Rs turbo
Old Sep 6, 2011 | 06:10 PM
155lee's Avatar
155lee
Default No spark on an Rs turbo
Bought a basket case s1 today and can't get it to spark,got power at the coil but nothing coming out,changed coil but still nothing.
Any ideas?
Old Sep 6, 2011 | 06:20 PM
B19LRW's Avatar
B19LRW
Its Broken.....
dizzy!check the plug / wires inside!
Old Sep 6, 2011 | 06:42 PM
155lee's Avatar
155lee
Wires seem fine,when I pull multiplug off the dizzy the metering head kicks into life.def power at coil
Old Sep 7, 2011 | 05:09 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Pics of car in question plz, is it a barn find?
Old Sep 7, 2011 | 05:18 PM
martysmartie's Avatar
martysmartie
The green wire is common for breaking, this is switched via the ECU.
Martin
Old Sep 7, 2011 | 05:21 PM
B19LRW's Avatar
B19LRW
Its Broken.....
yellow relay behind heater box!
Old Sep 7, 2011 | 05:23 PM
Zetecfiesta's Avatar
Zetecfiesta
id go with the green wire as well that runs along the front crossmember!
Old Sep 7, 2011 | 05:25 PM
paulhanzo83's Avatar
paulhanzo83
could be ur plug leads,roter arm distribiter cap
paul
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
adriansaleem
Aug 1, 2015 09:28 PM
