Ford KA Discuss your Ford KA here!
lambda sensor
Old Sep 2, 2011 | 03:59 PM
rp6770's Avatar
rp6770
Default lambda sensor
Hi all i have recently had the lambda sensor replaced on my 1.3 2003 duratec, the light has since come back on and saying the same part is at fault. Has any one had or heard of this problem could it be wiring or a connector. The car seems it little hesitant when going through the gears.
thanks in advance.
Old Sep 2, 2011 | 04:04 PM
oldford's Avatar
oldford
After-market part? Then the resistance of the heater can be wrong.
Or it can be wiring and in some cases even the ecu can be defective.
Or you replaced the wrong Oxygen (lambda) sensor.
What's the number of the fault code?
Old Sep 2, 2011 | 04:11 PM
rp6770's Avatar
rp6770
Thanks oldford
Garage replaced it after it took an age for them to get, i dont think its a ford part.
I took it to a mates garage this time, he did say what code it was i cant recall but did show me that it was bank 1 O2 sensor on top of the manifold.
Old Sep 3, 2011 | 10:15 PM
Hobomassiv's Avatar
Hobomassiv
There are two sensors, one at top of manifold one in pipe below.
I replaced my top one with an NGK sensor from a local motor factors for ~50 and it was perfect
Old Sep 5, 2011 | 08:27 PM
rp6770's Avatar
rp6770
Hobomassive
thanks mate i am hoping to try a ford one to see if that makes a difference or could it be wiring or a connector. and now the clock goes backwards......
Old Sep 5, 2011 | 10:13 PM
Shonky's Avatar
Shonky
V6 Ka of Love
A mate put a universal one on his street ka and didn't work, put an NGK on and it's been fine
Old Sep 12, 2011 | 07:49 PM
rp6770's Avatar
rp6770
Hi Shonky
that seems to be the general oppinion
thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
