ofac ofac difference?
OFAB and OFAC are the types of management. You can not run an OFAB chip on OFAC and vis versa. You can tell by the map sensors, ofab or ofac, are bolted to a plate on the back of the bulk head, behind and just to the left of the brake servo when looking face on into the engine bay. Search on google images to find out which one you have. If its OFAB i have a 195 chip
ofab will run more boost with a 3bar map (1 neg 2 pos)
ofac will run a small turbo escos map but thats 2.5bar again 1 neg etc
from memory
i also have full ofab managment with live map chip ready to go (still boxed from last waster)
from memory
im hopefully buying an airtec frontmount stage 2 i think,will have to cut bumper out to fit and a 195 superchip on ebay and a cheap pair of quad lights off a fella could ne1 tell me if £240 is a good price as i thought it was very cheap?
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
