Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Lowered Mk1 Focus front knocking noise
Old Aug 25, 2011 | 10:38 AM
Spurtboy's Avatar
Spurtboy
Default Lowered Mk1 Focus front knocking noise
I got my 2003 Focus Sport TDCi lowered but it makes a terrible knocking/creaking noise from the front which sounds mainly the driver side.
The knocking only occurs when going over bumps and is much more pronounced when turning slow bumpy corners like into a driveway.
There's no play anywhere and everything is nice and tight. The bushes look OK but difficult to tell about the ARB ones.
Tried searching for a thread about it here but couldn't find one, sorry if it duplicates. Anyone got any ideas? I've heard a few already but want to get some more advice.
Old Aug 27, 2011 | 01:09 AM
jpm360's Avatar
jpm360
Dont want to patronise you mate but have you checked the drop links ? My 2002 was doing the exact same thing . The steering also felt quite loose , hope this can be of some help . JP
Old Aug 27, 2011 | 08:15 AM
Spurtboy's Avatar
Spurtboy
Feel free to patronise, I'm not exactly an expert lol! The drop links seem OK but I've seen on other forums to try replacing them anyway or try longer drop links but I don't know where to get longer ones from.
I'm going to be polybushing it soon so I'll replace the drop links at the same time and see if that helps. Thanks pal!
Old Aug 27, 2011 | 08:22 AM
smudger068's Avatar
smudger068
i had this after i lowered my focus, and was because the mount were the lower part of the shock goes into wasnt tight enough just literally would of noticed it by eye, but quick run over all the bolts with a spanner cured it, I had to do it fairly tight though
Old Aug 27, 2011 | 08:26 AM
Spurtboy's Avatar
Spurtboy
OK, I'll have a go at that too, cheers mate.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
C2 MAK
Aug 20, 2015 09:46 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bezzy41
Aug 3, 2015 10:31 AM
