anyone changed alternator from mk3 mondy tdci??
Old Aug 18, 2011 | 08:03 AM
2wd saff cos @ stage 3's Avatar
Default anyone changed alternator from mk3 mondy tdci??
as title, my ones packed up so got another one and gunna do it at the weekend, ive herd there an easy job?
if any ones done one any tips or advise??
thanks
Old Aug 18, 2011 | 07:46 PM
fordghiarsxrboy's Avatar
fordghiarsxrboy
not a bad job comes out of the bottom,think you have to move the anti roll barlink to squeeze it out.
Old Aug 18, 2011 | 08:09 PM
fordnut's Avatar
fordnut
It is straight forward as long as you have the special tool required for the auxillary belt tensioner. Its not so simple without it.
The tensioner has two 1/2" holes in it in which the special tool fits. The tool is sort of y shaped so you can lever the tensioner back to get the belt on.
Old Aug 19, 2011 | 07:02 AM
ok thanks for the advice, i dont have the tensioner tool, so i think im gunna have probs, anyone no where u can get one?
Old Aug 19, 2011 | 09:06 AM
fordnut's Avatar
fordnut
Local car parts shops near you might stock the tool. Companies like Laser and sealey tools make them.
Old Aug 19, 2011 | 10:24 AM
ok thanks buddy
Old Aug 19, 2011 | 10:45 AM
daviddunlop83's Avatar
daviddunlop83
Or you can cut a 1/2" extension bar and use a spanner on the end of your really stuck.
Change the belt when you are that far along as its not easy to change and you have to remove the alternator if changing it.
Old Aug 19, 2011 | 12:11 PM
nice one thanks for that
Old Aug 20, 2011 | 05:50 AM
Did our one, had to bring it out of the wheel arch as it would not come out of the top or bottom,had to make the special tool aswell ,found it easier doing the gearbox change on my rs turbo
Old Aug 20, 2011 | 10:26 AM
yea i can see it clearly from the wheel arch, so thats a good starting point, im jus not looking forward to this belt as it seems to be a pain in the arse
Old Aug 20, 2011 | 01:31 PM
well the alternators loose, jus dont have a clue bout loosening this tensioner
Old Aug 20, 2011 | 01:49 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you have to do the air con pump, just pay someone, mine's been on the blink for 8 months and i've only just got round to getting it out of position
the petrol ones are a walk in the park
Old Aug 20, 2011 | 01:56 PM
i was goin to pay someone to do the alternator as i cant be bothered, but ppl are on hol or way to busy and i cant really wait as i have no car
Old Aug 20, 2011 | 04:31 PM
ok where is the tensioner? theres so many pulleys
Old Aug 20, 2011 | 05:17 PM
dojj's Avatar
dojj
take a pic?
if it was petrol i'd explain with pics as i've got one apart but the diseasal ones seem to be much more different
have you asked over on www.talkford.com ? as they know stuff even they don't know
Old Aug 20, 2011 | 07:09 PM
i have dojj but no can show me just how to loosen it, all i can get is how to remove it
Old Aug 20, 2011 | 07:27 PM
fordnut's Avatar
fordnut
Looking at the bottom pulley, the tensioner is just above to the left. You can't loosen it as such as it is spring loaded. I have some pics from when i did mine, i can try posting them if it would be of any help?
Old Aug 20, 2011 | 07:43 PM
that would be a big help if u could, thank you
Old Aug 20, 2011 | 08:10 PM
fordnut's Avatar
fordnut
If you pm me your email address i will mail them to you. I cant access photobucket for some reason.
Regards,
Nick
Old Aug 20, 2011 | 08:22 PM
fordnut's Avatar
fordnut
This shows the new one in place.
This one shows new and old on the bench, see the 2 x 1/2" square holes that the special tool slots into.
Nick
Old Aug 21, 2011 | 09:38 AM
nick you are a star, thank you very much
Old Aug 21, 2011 | 10:32 AM
fordnut's Avatar
fordnut
No worries mate. Good luck.
Old Aug 21, 2011 | 12:07 PM
any pics of the belt coming off the runner under engine mount up to top pulley and to alternator?
Old Aug 21, 2011 | 07:45 PM
fordnut's Avatar
fordnut
Sorry mate, i only took a couple to prove that it had been changed.
Old Aug 23, 2011 | 03:49 PM
ok, got it all sorted, couldnt get the belt lined up agen
jonfoc
16
Sep 11, 2018 05:35 PM
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
