Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
fitting a ET42 alloys to mk1 focus?
Old Jul 29, 2011 | 05:31 PM
andy130's Avatar
andy130
Default fitting a ET42 alloys to mk1 focus?
hello am fitting et42 alloys plus they need a spacer to hub(15mm), how much will the wheel sit out pass the arch? its a mk1 focus
Old Jul 30, 2011 | 01:30 AM
danme1987's Avatar
danme1987
Should sit pretty flush i think et42 is a good fit
Old Jul 30, 2011 | 10:45 AM
RichieST's Avatar
RichieST
Et42 is ok for a focus, spacer will take them to et27, which will make them stick out.
Old Jul 30, 2011 | 12:44 PM
andy130's Avatar
andy130
sticking out how much tho rich?
Old Jul 30, 2011 | 07:12 PM
RichieST's Avatar
RichieST
i guess about 15mm more than you would want them too will definatley catch the arches though!
Old Aug 1, 2011 | 12:27 PM
hogdog's Avatar
hogdog
Et42 is about the lowest you can safely go with a 7" rim. Going lower than that starts to present problems. A 15mm spacer will present you with lots of problems.
Old Aug 29, 2011 | 06:03 PM
pdfbt40's Avatar
pdfbt40
Not to mention the appalling scrub radius as well !
You've also not mentioned the rim width, or why you have to use spacers?
cossynut2
Aug 19, 2015 11:29 AM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
hazbaz1984
Jul 30, 2015 05:15 PM
