Loads of cheap Rs turbo parts
Old Jul 29, 2011 | 07:47 AM
robrs666's Avatar
robrs666
Default Loads of cheap Rs turbo parts
Right hi guys my project is coming to a end so have loads of bits left so I'm having a clear out,
all parts as listed paypal as a gift only please
Standard Rs turbo mfi flywheel ideal for skimming while yours still on the car £15 inc post
Drivers headlight new never fitted brought from euros £15 Inc del
Steering surround top has a small led in it bottom has a small switch on side £12 Inc post
Thermostat housing good condition isn't from s Rs turbo as the sensor hole is in wrong place maybe efi or fiesta please see pics at end £12 Inc del
Rs turbo fuel pipes general different ones metering unit etc £12 Inc del
Servo to inlet pipe £10 Inc del
Indicator brackets new never fitted £5 Inc del
Indicator / wiper arms UNTESTED £10 Inc post
88 spec roof clock again untested £7 Inc post
Full set of valves,rocker arms , spacers ,collets etc all bagged in the right order everything you need to build a head all used £20 Inc del
Gearbox mounts not the cradle type came from my LSD box I brought rubber looks ok £12 Inc del
Alternator bracket genuine ford £10 Inc del
Clock surround needs a good clean but all ok £12 Inc del
Rear wiper motor worked perfect when removed £20 Inc del
Standard cam cover Inc rubber £10 Inc del
Rocker cover will need painting etc but all ok £12 Inc del
Headlight rear covers only need a clean £7 Inc del
Standard s2 engine mount no rubber but ideal for Zvh
conversion £12 Inc post
Old Aug 6, 2011 | 08:24 AM
mdbs's Avatar
mdbs
Hi, new to forum, having some top end rattle issues so might need some good rocker arms etc. How good are yours?
Thanks.
Old Aug 6, 2011 | 11:40 AM
robrs666's Avatar
robrs666
They're sold mate good luck anyway mate
Old Aug 6, 2011 | 02:22 PM
mdbs's Avatar
mdbs
OK, thanks, can I ask a question about my rattle?
Old Aug 6, 2011 | 02:42 PM
robrs666's Avatar
robrs666
If you like mate
Old Aug 6, 2011 | 06:55 PM
mdbs's Avatar
mdbs
Not sure what the engine is exactly but Zetec block, 2.1, CVH head, forged pistons etc etc runnig at T3. Fitted to an Escort RS Turbo.
Cam is fine, new lifters fitted and tightened as they should have been at correct torque and method. No reason to think oil pressure is low. Engine is spotless inside.
But there is a light rattle, comes and goes, but mostly its there, sounds exactly like one or two lazy lifters.
some of the rocker arms will move in a twisting motion if you try to make them, as if they are worn, but they dont look obviously worn out, some wear marks but not trerrible.
Questions, anyone have any ideas? Also, do the rockers need replacing sometimes or is it never heard of? Should the fulcrums "fit" nicely in the rocker because these dont really, but I am being picky there.
I would assume from the spec of the engine that it was built by someone who knew what he was about but of course you never know.
Old Aug 7, 2011 | 01:05 PM
robrs666's Avatar
robrs666
Some of the rockers will move mate depends at what point the cam is at mate a slight rattle is normal really the Cvh head isn't known for being quite what oil are you using in it as I use a high grade oil and it's very quite mate
Old Aug 7, 2011 | 05:01 PM
bubs_rsturbo's Avatar
bubs_rsturbo
hi mate is the 88 spec roof clock still available? looking it posted to northern ireland
Matt Baxter
Sep 16, 2015 08:30 PM
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
