Fault Codes
Old Jul 27, 2011 | 03:44 PM
RSMish's Avatar
RSMish
Default Fault Codes
Hay Guys,
Im a newbie on here, so go easy please. lol
Ive just got a focus ST170, paid £500 for it so can't moan but its got a few thing wrong with it that i can't work out and was wondering if any of you can help.
On the dash it comes up with DTC 9359. Iv'e heard it is ignition Run/ ACC Circuit Failure. Is this right?
The Air Conditioning its working at the moment as it has a leak in the raidiartor part at the front. So there is no gas in it.
When i plug it in to the dygnostic comp it comes up with #Bank 1. I know thats the lambda sensor but not sure if its before the cat or the one after. :-S
The Dash gauges randomly don't work then as your driving they kick in and they all start working.
Finally the whole time the car is running its making a clonking noise. But sometimes it randomly stops the does it again. Im not getting full power until 5000 revs and normally you get it about 3-3.5000 revs. No other faults come up on the dygnosics ...
so dont know what to do.. please help...
Mish....x
Old Jul 27, 2011 | 04:06 PM
oldford's Avatar
oldford
There are more parts than the Oxygen sensor that also have the addition Bank 1.
What's the number of the fault code(s) you read out with the Diagnostic equipment?
Old Jul 27, 2011 | 04:10 PM
RSMish's Avatar
RSMish
I dont know it just come up with bank 1. sensor 2. :-S
Old Jul 27, 2011 | 05:13 PM
oldford's Avatar
oldford
Sounds like the Oxygen sensor after the catalyst.
But that's not the cause for any of your complaints.
I wouldn't call what you are using a "Diagnostic computer", if it does not give trouble code numbers and it gives false texts or only the part of the trouble code text.
Besides this "tool" will only read the engine - not anything else.
I would get the codes read by somebody with a better tool - like the dealer.
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
