FRST Engine Rebuild advice needed
Old Feb 13, 2005 | 03:26 PM
McCloud 85's Avatar
McCloud 85
Default FRST Engine Rebuild advice needed
Currently fully rebuilding an FRST engine, and need a few of questions answering.
Can i use a graphite grease to lube up the main bearings and conrod bearings or is it best to use engine assembly lubrication?
I was told to use graphite grease around the piston rings, is this true?
Is Loctite the best stuff to use around threads on things like oil gallery screws?
Will O.E piston rings from somewhere like Burton Power be good enough to handle 200 bhp and about 14psi, or is it best to find uprated ones? (using standard pistons)
Any help much appreciated
Old Feb 15, 2005 | 07:31 PM
McCloud 85's Avatar
McCloud 85
anyone able to help??
Old Feb 16, 2005 | 09:30 AM
tinasmartin's Avatar
tinasmartin
dont use graphite lube allways use plain engine olie ore assembly lubricant..
use a little engine oil on the pistons just so that it does´nt rund metal to metal
loctite is good on any bolt tread ( not to much )
and yes they should do the trick at that pressure too (piston rings)
big_Rad
Sep 15, 2017 09:36 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
knight19770
Aug 4, 2015 12:36 PM
