grpA coil
do you have to change the spark plug gaps once fitted and if so what do you gap them to???
i`m sure my gaps are 24 or 25 thou at the moment.
I just bought a car a 2wd sapph from on here and it had a missfire on boost, i have changed the plugs but now runs slightly rough at bottom end (say from second into third it will splutter for a sec then be ok) Would a group a coil help me??? Getting it set up soon but i live on the isle of wight so want it running better to get it somewhere.
