What turbo is.....
this??
basically it came off of my mates spare s2 engine he has in his garage, i snapped it up!!
on the top of the turbo it has 3 inlets/outlets the two that are circled in the pics i know about but what is the 3rd pipe(?) help
will it be easy to fit to my s2 or will i have to get a proffessional? how much will it cost for a straight turbo swap?
any help much appreciated!
cheeRS lads
cheeRS lads
the 3 outlet/inlets u highlight, are for water and oil, but the one which is sticking up :S
that should be under the tubo also for water, correct me if im wrong
but thats what i think
sim
yes its the 1 on the left should be pointing down & is a water pipe (feed/return)
the middle is the oil feed
the 1 on the right is the water pipe (fe/return)
just looks like a standard t3 escort turbo to me!
JK12
33
Apr 26, 2021 12:09 PM
