Ford KA Discuss your Ford KA here!
Ford ka custom radiator
Old Jul 24, 2011 | 02:52 PM
thomasf's Avatar
thomasf
Default Ford ka custom radiator
I have recently bought a escort rs turbo engine and was wondering what I need to do to my radiator so that the T3 turbo will fit...or will a radiator from a different car fit and if not, where can I go to get a custom made radiator?
Old Jul 25, 2011 | 07:05 AM
Hobomassiv's Avatar
Hobomassiv
You will have to make the radiator L shaped to clear the turbo.
Old Jul 25, 2011 | 02:51 PM
thomasf's Avatar
thomasf
cheers...however im poo when it comes to mechanics, how would i make it L shaped?
Old Jul 26, 2011 | 02:17 AM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
(i think hes an arse and hes trying to take the piss)
move the turbo or move the rad mate
Old Jul 26, 2011 | 03:42 PM
thomasf's Avatar
thomasf
sound , so im guessin its possible to move the rad forward a little bit...but how much?
Old Jul 26, 2011 | 10:20 PM
mk3cosproject's Avatar
mk3cosproject
ford crazie
most get rid of some of the front slam pannel just beside the headlights and make up a new bracket to hold the rad and move it out a bit. how much is depending on which rad you are using. my presumtion is the origonal rs turbo rad???? there are threads on the kaklub which show various members using the standard rs. they dont have to move it much forward but a whole new bracket is usually made for the rad and the bonnet catch. there was a white rally ka in performance ford a while back running a 1700 puma which had the same job done look that up.
Old Jul 27, 2011 | 07:10 AM
Hobomassiv's Avatar
Hobomassiv
Yeah, im taking the piss obviously.
If you are running the T2 Fiesta manifold and turbo then you will clear the rad.
If you are running T3 YOU WILL HAVE TO HAVE AN L SHAPED RAD or a custom made and mounted one behind the bumper (involving cutting slam panels and removing the bonnet catch etc etc.)
Im going to be using a zetec turbo with T3 manifold and turbo and i have the exact same problem.
Old Jul 31, 2011 | 04:03 PM
NoRubNoDub's Avatar
NoRubNoDub
how much extra room is needed? over 20mm?
Old Aug 9, 2011 | 04:32 PM
zippyka80's Avatar
zippyka80
Default rad set up
or just buy my rad setup as it was fitted to joey p old ka and is fitted to back of ka where rear seats whould be
Old Aug 9, 2011 | 10:08 PM
mk3cosproject
ford crazie
any pics
SmudgerByName
52
Jul 28, 2016 06:14 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
Churtz
Aug 3, 2015 08:19 PM
