4x4 Cosworth engine (HIGH SPEC)
Old Jul 20, 2011 | 01:38 PM
chrisreid's Avatar
chrisreid
Default 4x4 Cosworth engine (HIGH SPEC)
Hi you are looking at my 4x4 cosworth engine from my racing car. The engine has had a full rebuilt and has only done two race meets at Knockhill (10laps a race). I am needing £5500 O.N.O
This is the spec and what you will be getting.............
Harvey gibb built bottom end
long studded 200 block
fully lighten & balanced
forged pistons
valve cut out's
7:8.1 c/r
Neil Roper ported and polished head, 25mm inlet/exhaust ports, double valve springs, new valves and guides, bd14 inlet, standard exhaust cam.
Vernier pullys
Modifed inlet manifold with plenum spacer
reyland alloy fuel rail
83lbs siemens injectors
2wd exhasut manifold with trouser spacer
GT30-71r (4" inlet) turbo with uprated bearing housing (internal wastegate)
Air injectors
L8 ECU/MSD closed loop
Modified 5 stud downpipe to suit turbo
gated sump
new HP oil pump
new water pump
Brand new sensors all round
New alternator
New starter motor
New BLUE motorsport leads
powersteering pump
Any questions then just ask. My email is c.reid444@hotmail.co.uk
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
