car wont stay running
hi, escort rs turbo,,it starts for a few seconds then dies. then wont start unless yu leave it for few minutes. its bein used wit a 1.1 fuel pump could this be the problem, sounds stupid but has enough fuel to start it. hope someone can help.thanks
At a guess its running lean, it starts up fine with the cold start injector/fast idle, then dies as the injector is cut off.
Im not saying the pump is the cause but don't be a pikey. Then get your self down to someone decent for a set up.
PS, mine was doing this a few years ago because i had a slight air leak so the car was running weak.
Rob,
Rob,
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
