Thinking of breaking my big spec 3dr mint 500bhp+ car
Full car at the mo just havent got enough money these days to keep a car like this which is a shame as i love it to bits..
First off is the engine:
New 200 block
forged pistons running standard compression with big vavle cut outs
standard grind crank
fully lighten and balanced bottom end
new stardard rods
arp everything
wrc gasket ( told by grace engines who built it its 6 long studs) with arp bolts in the rest
uprated oil pump
2wd sump
grace engines race spec head
custom grind cams to grace engines spec (perfect for rb turbo)
3 angle seats, new guides (the lot)
this is still in car so can be heard running and is in a 520bhp 3dr detuned to 450bhp @1.5 bar and has done 6/7k faultlessly.
£3k complete with all timing gear ect ready to bolt in. SOLD TO MATT BAXTER
Then
gt35r garrett roller bearing turbo with tial external wastegate and screamer pipe and reyland modified 2wd manifold and down pipe so complete bolt on conversion rated to 600bhp+ also comes with the boost pipe to intercooler new from rouse motorsport
£1000 MAY SPLIT THIS SET UP IF THE TURBO SELLS FIRST.
autronic sm4 ecu with braided loom, all sensors , twin wasted spark coil packs with all leads and ignition ect with switch and wiring for anti lag was all done by mark shead at over 3k new and comes with 83lbs siemens and fittings and every piece of ignition so bolt on kit
£1400 PROV SOLD TO JAMES90RS
spec r breather system full custom tanks for cossie with aeroquip fittings and custom brand new adaptors and aeroquip hoses.
Kit only done 300 miles and comes with brand new fittings and powder coated gloss black with all the fittings and adaptors this is nearly 600 new
£350 sold to carl
brand new still in box vibratechnics competition engine mounts 2wd 200block £160
genuine r&b motorsport swedish inlet complete with cometic gaskets and brackets and throttle bodie so full bolt on set up £200
quaife diff custom built for the car and cost £1300 and only done 2k miles still looks new and drives faultless £750 this diff is wicked and makes the car handle realy well, and is still like brand new prov sold
lenso bsx alloy custom made for a 3dr with chrome lips and caps and black centres with new tyres in: fronts 17x7.5 and rear 17x8.5 et25
this fit perfect for a 3dr and the only 17" set on a cossie at the mo £600 (SOLD TO 3DR COSSIE)
whole rolling shell complete minus the stuff listed above
check out my resto thread i will add the link in a min.
fully repainted and looks mint in moonstone and comes with everything left and has a yrs mot and 6 months tax lol
the whole car was painted 500miles ago and looks brilliant and it was all done except the engine bay and bonnet but the car is now very nice and has got alot of attention since being back out on the road.
coilovers
polybushes
full interior with drift style steering wheel and boss
£1000 worth of sterio sound the tits
£500 worth of alarm
rs500 splitter and fog grills
full exhaust except down pipefull brakes allround which have only done 2k miles and are uprated allround#
all lights the lot hoses, tanks breather kit
rs500 cooler
xs power alloy rad
need fan loom
alloy power steering tank
alloy header tank
044 pump and full fuel system ect which has powered 500bhp fine
and this 3dr seems to handle realy well compaired to all the others ive driven its set up realy well and drives lovely so only breaking as its worth 3k more in bits ....
basicly you will need an engine, turbo loom diff
bad bits two small bits of rust in engine bay ive been quoted £250 to get done perfect so £4500 complete as is or £5000 without a fault complete
which is a bargain due to only needing 2k (at most) worth of bits...and will be worth 9/10k all day long and also comes with loads of history and has only covered 81k from new and can come with a realy good t5 box aswel for an extra £100? but comes with all your props and shafts ect anyway
SOLD TO JAMIE
New 200 block
new stardard rods
arp everything
uprated oil pump
2wd sump
Then
£350 sold to carl
coilovers
polybushes
£500 worth of alarm
rs500 cooler
xs power alloy rad
need fan loom
alloy header tank
SOLD TO JAMIE
If your breaking
Where the price shell complete car interior !
just help cash wise !
And when you say arp everything how the head done arp or stud nut 6 !
diff and loom and ecu...
and will need a set of alloys lol
but its a driving car at the mo with yrs mot and 6 moths tax....
the engine is ment to have 6 studs and arp bolts through out the rest and also has heavy duty mains ect only done 6/7k and is a genuine 500bhp motor
its this breather kit with brand new fittings whole kit cost nearly 600 will take 400.
inlet
car at brands hatch the other week, this is after 300 miles in the rain lol
inlet
Mint Car though pal, you must be gutted. Good luck with sale. If youre interested in my motor let me know and I'll tell you what comes with it. CGI block etc, you might get your 5k selling off the spare bits or at least a good wedge of it.
that will leave me with between 8/9k for my next car so will most likely be a frs lol
Mines nice 365bhp proven with full H&R coilies and rollbars, comps with 888's and a mountain of spares inc a new fresh cgi block with forged rods and pistons etc.
mmmmmmm you know you want it, look in to my eyes not around my eyes but in to my eyes...........
loom
twin coil packs that are like a grand them selfs
leads and full igition set up
all engine sensors
wiring for anti lag with switch ect for switchable mapps...
i wanted £1500 for the lot and can come with siemens 83lbs and fittings but wanted £150 for them but the management was £3100 new lol
we could sort something if you want it all
so yes everything to fit and run and can be seen running before i remove it
Ok mate no problem it's all here and running for the 1500 you can have all the injectors and fitting, and every single sensor on the engine so is at least 3.5k worth of stuff that runs lovely
When I broke up my s1 I delivered the rolling shell to the other side of Harrogate from Bracknell for full asking price and fuel lol took me 14hours lol
its my mate simons hes just finished a 2 1/2 yr build and its the straightest x pack you will ever see and is proper mint and paint is stunning.
is built for 380bhp yb with all the best bits on the market, and 2k worth of wheels custom made to fit ect. all the best suspension you can put on a mk2 .
hes looking for another escos or might sell that for 14k which if i had the money i think its worth alot more
some prices lowered to meet prices today....
everything ive listed is a hell of alot cheaper than market value and is real good condition stuff and top quality
this will be a just put on and get mapped to you spec set up, nothing will be needed
pm me if you want to come and see it,
its all still fitted to the car so can be seen running and comes with its own built in boost control valve, and i will give every engine sensor ect, alone with all the wiring to the anti lag switch, coil packs, 83lbs siemens, all the ignition parts like leads dizzy ect....
