Efi rs turbo greens??
Old Jul 10, 2011 | 02:30 PM
mk1turboestate's Avatar
mk1turboestate
Default Efi rs turbo greens??
iv built up a 1.8 zvh rs turbo engine running efi with ofac fiesta managment, i already had the engine but it was mfi,
i bought the inlet manifold complete with fse boost valve and greens with numbers 0280150802 on them, the ecu isnt chipped yet iv just been trying to get it running.
will the greens overfuel because when it starts it seems like it??
Old Jul 10, 2011 | 03:52 PM
martinmilne's Avatar
martinmilne
think you need the chip to control the bigger injectors
Old Jul 10, 2011 | 04:05 PM
studabear's Avatar
studabear
The greens may well be bosch 803's, which iirc are not suitable for ofac/ofab
Old Jul 10, 2011 | 04:54 PM
luke19790_3's Avatar
luke19790_3
you need blue injectors, think the xr2i and turbos used the same ones.
Old Jul 10, 2011 | 05:07 PM
mk1turboestate
so will it over fuel then?, if it is chiped will the greens be suitable?
Old Jul 10, 2011 | 05:23 PM
luke19790_3
the chips that i've seen are for beige injectors. would need a custom chip
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
