obp pedal box brand new
bought this brand new and is no longer needed for my project so selling looking for £250 plus postage good saving instead of buying from obp at the price i paid
chears alan
Rally Kit Car All In 1 Floor Mounted Pedal Box Hydraulic Clutch
OBP0005
View Full-Size Image
Quantity:
£333.77
All In 1 Floor Mounted Pedal Box Assemly
Totaly new design with less weight, oil impregnated pivot bushes and fitting holes in the pedals!!
Sizes: Pedal Box 230mm Long x 130mm High x 130mm Deep and the Pedals are 250mm at max height. (Approx)
Bias Bar: 35mm Long Mild Steel 7/16 UNF Thread cenre piece, Central ball 25mm Radius, 2 x Alumimium Clevis with 3/8 (to fit most cylinder push rods) Approx size. Pedal Ratio is 5.5:1
This pedal box is fitted with a bias bar system and dual master cylinders. This gives a twin fully adjustable braking system using 2 master cylinders. This unit has been fitted into all types of cars from kit cars, race cars, hot rods etc. It is a very versatile system. This pedal box is a floor mounted Bias Brake System, Clutch and Accelerator pedal all in one unit. Stop giving yourself grief and get an easy to fit Pedal Box, this will make your life and build so much easier.
Kit Contents: 3 x Pedals, 1 x Pedal Box, 1 x Bias Bar, 3 x Master Cylinder, 3 x Reservoir, 1 x Reservoir Bracket
chears alan
OBP0005
Quantity:
£333.77
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
massivewangers
30
Oct 1, 2015 07:40 PM
