s2 arb size?
Jul 5, 2011 | 10:00 AM
s2 arb size?
what diameter is the std arb on the rear of a s2 turbo. Im sure they are 12mm. Anyone confirm. Was there only 1 size used on the s2?
Jul 5, 2011 | 10:08 AM
thought it was only s2's that came with an rear arb
Jul 5, 2011 | 10:26 AM
Jul 5, 2011 | 10:29 AM
I thought they were 16mm?
Jul 5, 2011 | 11:49 AM
i thought if you have a rear arb then it can only be for a s2 escort? that was my thinking
Jul 5, 2011 | 12:09 PM
Orions come with a Rear ARB, XR3i's and cab's don't... I thought Orion and RST were the same but, it seems Series 1 turbos use a 12mm from an Orion, and a series 2 turbo uses a 16mm.
I would like a 16mm for my Orion!
Jul 5, 2011 | 01:05 PM
Jul 5, 2011 | 01:42 PM
i have a s1 but i got a s2 roll bar. Need to order bushes but will wait to get home before ordering
Jul 5, 2011 | 04:51 PM
this is why im not sure
in the back of me head i keep thinking isnt it 16mm?
Jul 6, 2011 | 07:11 AM
S1 = 12mm
S2 = 16mm
Chaffe - howd u bolt 2 together?
Jul 6, 2011 | 07:21 AM
Quote:
Originally Posted by
Rogeyboy
S1 = 12mm
S2 = 16mm
you need four clamps (two close to the body mounts and two very near the ends of the arb) and clamp them up. Clamps will have to be made either by you if your handy or by a machinist. Get four 2" long pieces of 1" square bar, drill two holes in each (same size as the arb) and one central hole for the clamp bolt, then split in half lengthways.
Jul 6, 2011 | 10:08 AM
Have you tried this?
Just leaving the standard bar to body and bar to rear arm mounting points?
Jul 6, 2011 | 11:31 AM
Rogeyboy
i did it on the front of an old escort once
boeb
Jan 9, 2020 05:11 AM
Fezman1
Oct 2, 2015 01:22 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
alexbarnes95
11
Sep 15, 2015 10:26 AM
