Idle dropping off
Old Jul 1, 2011 | 09:49 PM
carr955's Avatar
carr955
Default Idle dropping off
I have just purchased a 1996 Mondeo 2 litre ghia estate, and sometimes when you pull up or are changing gear the Idle will drop off to nothing and the engine will die, it fires up straight away again, Just wondered if anybody has any ideas, Plus how do you reset the E.C.U. Many thanks Simon.
Old Jul 1, 2011 | 09:52 PM
RichieST's Avatar
RichieST
Idle speed control valve, very common on the zetec engines. Whip it off and clean it with carb cleaner, if its no better then will need to be replaced.
Old Jul 2, 2011 | 07:52 AM
frego's Avatar
frego
Default Idle
Thanks Ritch, Where is it located on the Zetec, Thanks again Simon
fordrallycar
Sep 30, 2015 07:57 PM
Marv888
Sep 26, 2015 03:44 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
