Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus MK1 digital heater/aircon panel
Old Jun 30, 2011 | 12:37 PM
will16v's Avatar
will16v
Default Focus MK1 digital heater/aircon panel
Hey,
Anybody know if a MK1 Focus Ghia digital heater panel with fit strait in my Focus (which currently has the twisty dial fan and temp switches)?
Or will i need extra wiring?
Essentially, they both do the same thing, its just that one is digitally adjusted, the other (mine) manually...
Old Jun 30, 2011 | 02:24 PM
Bailes1992's Avatar
Bailes1992
Would love to know the same cause I fancy climate control.
For starters though there is a UV sensor on the dash, but I don't know about anything else.
Old Jun 30, 2011 | 04:51 PM
will16v's Avatar
will16v
I've just found this:
http://www.talkford.com/topic/150144...ls-to-digital/
*EDIT* - sorry, thats for the Mondeo
Old Jul 4, 2011 | 09:57 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
The control panel is a straight swap for the twist dials.
But changing it over will do fuck all as - in order to make the auto system work - you need to rip out the entire heater matrix and fit the auto one which has stepper motors instead of twisty cables.
To change the heater matrix is a dashboard out job and then remove all the crash bar and shit behind it. The air con system needs to be professionally degassed before you start then regassed afterwards (£50 a time) and that's before you tackle the wiring side of it - EATC was only ever fitted to cars with GEM modules (facelift models) so if you have a pre-facelift car (which runs a PCM) then you will run into some interesting side effects. Losing the use of your heated front and rear screens being the most noticeable.
I'be done the conversion before. It's a complete fucking pain in the arse to do and considering the sacrifices to be made, not to mention the costs involved, it's REALLY not north the hassle.
P.S. The EATC system is shit anyway. In auto mode you either get red hot or ice cold air until the desired temperature is reached (usually fucking ages) and if you set the temp manually you might as well be using manual dials.
All in all - don't bother.
Old Jul 5, 2011 | 08:03 AM
Bailes1992's Avatar
Bailes1992
So you can just plug one in and it would work? Just not the Automode?
Old Jul 5, 2011 | 02:50 PM
Davemurphy007
You'll have absolutely nothing, no heating and ventilation controls at all.
Old Jul 5, 2011 | 11:24 PM
danme1987's Avatar
danme1987
its a massive job. seen a how to somewhere
155lee
Sep 6, 2016 11:10 AM
JamboRS
28
Sep 14, 2015 09:02 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
natehall
Sep 8, 2015 05:13 AM
gavt123
Sep 5, 2015 10:03 AM
