AIr con not working
Old Jun 27, 2011 | 09:24 PM
bampson's Avatar
bampson
Default AIr con not working
Hi
My Aircon is not working so i called one of those mobile gassing guys and he gassed it up but the compressor would not click in .
he said he cant get involved with the compressor issues and left me £75 down :-(
I have checked the fuses and the relay but nothing wrong there , i also checked the current to the compressor and nothing ..
so I guess my question is what else can I check / do to get the current to the compressor ?
any help would be appreciated ...
thanks
Old Jun 27, 2011 | 09:27 PM
RichieST's Avatar
RichieST
Could be pressure switch. It's in the system somewhere and senses low pressure and cuts the pump out to avoid damage. A bit of simple fault finding is all it takes, i think he ripped you off to be honest. You paid him to fix your air con and he hasn't done so!
Old Jun 27, 2011 | 11:07 PM
bampson's Avatar
bampson
That's what i said mate , but his answer was "you paid me to gas it up and i did"... wont be using him again ...
Old Jun 28, 2011 | 06:59 AM
domino's Avatar
domino
should of told him to take it back out then as its broken
Old Jun 28, 2011 | 07:12 AM
Danster76's Avatar
Danster76
Did mobile man have a chunky looking machine (proper kit) or a bottle of gas and some gauges?
IME its most unlikely (but not impossible) to be a mechanical faulty and should just require a gas service like this;
  • Check for pressure and refrigerant in system.
  • Recover and measure amounts of gas & oil remaining.
  • Purge air from system.
  • Deep vacuum system for a minimum of 30 minutes.
  • Vacuum hold to check for minor leaks.
  • Replace oil correct for the system.
  • Charge with new refrigerant (correct amount for the system).
  • Add UV dye to system so any future leaks can be detected and label car with information sticker.
  • Run system and check pressures and performance.
  • Print out of service information.
More...
Air-conditioning (A/C) system in modern cars is a complex system that requires periodic maintenance. Most often, the system needs topping up using specialist equipment that is used to calculate the necessary quantity to accurately top up the system.
The A/C system on most cars will loose 10-15% refrigerant per year under normal use, more if not used during the winter! We recommend the system is serviced every 2 years to keep it at optimum efficiency.
Old Jun 28, 2011 | 05:55 PM
bampson's Avatar
bampson
how can i test the Low presure switch ?
Old Jun 29, 2011 | 10:10 PM
bampson's Avatar
bampson
anyone ?
Old Oct 14, 2011 | 11:28 AM
g_davison's Avatar
g_davison
iv got the same problem... my aircon only works if i have it on full blast which is not very clever but im having mine serviced next week as iv only just bought it, so il most likely ask the garage to look at it for me
Old Oct 14, 2011 | 12:15 PM
Sp3no's Avatar
Sp3no
£75 for a regas, there is no need to pay over £35
lee2cossies
Aug 26, 2015 10:04 PM
rdvil
Aug 15, 2015 12:11 PM
Ben26
Aug 11, 2015 04:19 PM
