Which wire is the Fuel pump feed in an esc cos fusebox??
Old Feb 11, 2005 | 11:35 AM
DaveEscos's Avatar
DaveEscos
Default Which wire is the Fuel pump feed in an esc cos fusebox??
THere are a lot of them!
i thought black with a red line but theres a few of those too!
Old Feb 11, 2005 | 12:35 PM
cossiemen's Avatar
cossiemen
Whassup
check this out mate
http://www.siipicossu.com/manuaaleja/manuaalit.htm
Old Feb 11, 2005 | 06:42 PM
DaveEscos's Avatar
DaveEscos
cheers mate, a very good link
but doesnt help my question so bttt
Old Feb 11, 2005 | 07:44 PM
ECU Monitor Enthusiast
DaveEscos,
The easiest place to find the fuel pump wire is in the passenger foot well on the
fuel pump inertia shut off switch.
This will drive a relay to drive an uprated pump if this is what you need.
Plus will shut the pump off if you crash the car !!!!
Old Feb 11, 2005 | 09:09 PM
velocity's Avatar
velocity
its a black and red wire from fuse 5 and same colour all the way to the inertia switch and all the way to the pump
Old Feb 12, 2005 | 06:49 AM
I thought the fueling wires were all seperate from main fuse box on all cossies ?
Old Feb 12, 2005 | 08:34 AM
DaveEscos's Avatar
DaveEscos
cheers simon and velocity
basically weve used the feed to the inertia switch as when we removed the std vecta imobiliser.. the fuel pump wouldnt work
now when the key is in the ignition the pump keeps priming.. ie it doesnt stop
Simon, i dont suppose you fancy a drive down to have a look o you
Old Feb 12, 2005 | 08:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
dingy,
No the escort uses the full production fuel power system Steve. Only the sierras were assembled as seperate systems.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
