How much boost are you guys running on your standard frs engine+turbo?
Old Jun 25, 2011 | 07:51 PM
turborob's Avatar
turborob
Default How much boost are you guys running on your standard frs engine+turbo?
Wondering what you guys are running your mark1 focus rs lumps? I need to put on a new actuator but wondering what a nice safe boost level might be for mine..........standard engine internals and standard turbo.
Running a k+n and dreamscience though, 222bhp at the wheels with a weak actuator
Any suggestions??
cheers
Old Jun 25, 2011 | 09:53 PM
GribbiN's Avatar
GribbiN
22psi with forge actuator running direct before i went hybrid
Old Jun 28, 2011 | 02:53 PM
scubastevo's Avatar
scubastevo
Same here peak 22psi stable at 19 above 4000rpm with the forge item.
Old Jun 28, 2011 | 07:31 PM
turborob's Avatar
turborob
cool, thanks guys. Gives me some figures to keep to
Old Jun 29, 2011 | 03:13 AM
scubastevo's Avatar
scubastevo
Just mentioning the boost is with a Ford motorsport manifold not sure if the normal mani will take it.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Toe Knee
Aug 23, 2015 08:31 AM
c20tbo
Aug 17, 2015 10:19 PM
Neatrags
Aug 16, 2015 07:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
