HELP,diagram for greys
Hi all,
Can anyone help me i have just bought a sett of greys and a fitting kit and there is no instructions i have not got a clue which order the washers,o'rings and spacers go
Does anyone have any diagrams or even explain which order they go in.
Cheers all it would be a great help
Regards Paul
Regards Paul
Originally Posted by seveneigths
Cheers Alvyn,is there any order i should put them in?
after fitment just turn on the ignition so fuel pump is pumping up but NOT starting the car to make sure that there are NO leaks from the fuel rail,regulator etc b4 you start the engine! if ok then fire it up!ps have u also upgraded the fuel pump to an 044 group A type?
