s2 loom and running gear into mk3 escort
Basicly my mk4 died of rust and I've got a clean base mk3 shell to put it in.
I take it the s2 loom won't fit the mk3 clocks or swithch gear,
So am I better or converting it over to efi ?
Also can I run the gearbox craddle and s2 front anti roll bar ?
the gearbox craddle can be made to fit but you will need to mod the cross member. not sure if the arb set up can be used but i'm sure someone else on here will know
