help please?!! saf morrettes question
what exactly needs modifying on them to fit
i know youhave to trim them down for the grill to fit
but what about
the lower strip as my strip doesnt exactly fit right on them
where the 3 prongs are on the strip the middle one has a little catch
well that catch doesnt come out any where near the hole on the cover
does the bump on the cover need trimming back so it locks in or
am i just being picky
but what about
Originally Posted by Sticker Paul
Morrettes will just fit straight on, on cutitng is required.
Just need abit of patients to get them perfect.
paul did you have a hangover
They're designed for a standard Sapphire and the Cosworth grill is wider.
But its only on the inside edges.
That strip under the grill and lights never seems to fit properly!
Yeah, you just need to take a notch out between the top and bottom screw holes for the grille on the insides if that makes any sense. It's just to clear a bit of the grille.
yeah thats what ive done
just when all on the strip underneath doesnt fit very well anymore
but sod it now just gona have to live with it i supose
thanks
caprisean when u gona fix ur rear bumper
whats broke on it the little lug, if so i had one break on its very easy to repair
thanks
