S1 arches on an S2 how hard?
I suspect the 8j rims and 235 tyres i now have for the rear of the Gartrac may be a little too wide for the S2 arches! How much work is involved in fitting S1 arches and are they easy enough to get???
Cheers Spadge...
Cheers Spadge...
wont give ya any more clearance spadge...IIRC the actual steel arch on the s1 is the same as the s2, it just looks wider as the s1 bodykit sits fully over the arch rather than just the lip on the s2.
fook that then i'm after something that works not just something that looks good Trending Topics
spadge have a look at the F2 escort wrc rally cars from a few years back they had arch kits on them because of wide track, its an idea and is def a motor sport look which is what you are after.
Just been looking at some pics of my car and the way the rear wheels sit in the arches now and i might just get away with the extra width! The Rondells on the rear at the moment are ET36 and 7.5j and have 205's fitted so the ET35 8j 235's will only sit out about 15mm max more! What do you reckon?
you may just get away with it mate
try em on and have a look and take a pic and compare
i take it the rear arches have been rolled ?
may want to do that also mod the rear bumper at the top
as when squat it may catch there
but car still the bolox
sridgett
Oct 1, 2015 07:30 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
