need help with rsturbo zetec
hi I have just been given a S2 turbo with zetec bottom end been told it runs but very lumpy I dont know what size the bottom end is or how to find out. I was told that the pistons have been changed and it has stage 1 head not sure if the timing has been set up correctly the cam pully has been changed picking the car up in 10 days time any advice or ideas please
thank you
thank you
with what you have listed there i think it would be hard to diagnose and/or help you out without actually seeing the engine in person.
best bet would be to wait untill you pick the car up and maybe ask your questions then, if its running a zetec block it will have the dipstick at the front left of the engine (as you look at it) the engine size will be cast into the block roughly centre half way up.
if you are compitent on the tools though none of what you said is a major issue.
Ah thats good to here, would hate for someone to go into a rs turbo not knowing potential pitfalls, it was when you said it was given you
How was it running prior to not getting used? was it running lumpy then or is it since its not been used?
if your in it for the long haul then it'll do no harm for you to strip the whole engine as you said your not entirly sure what build it has. it may not be anything major but at least you will know more than just guessing.
do you know what management its running, chip etc?
when you can get some pics up
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
