Ford Puma Discuss the Ford Puma here!
puma with idle issuse
Old Jun 13, 2011 | 02:38 PM
Northants Ford Fan's Avatar
Northants Ford Fan
Default puma with idle issuse
Hi guys,
I have recently bought a s reg 1.7 puma, for some reason it is idiling at about 1200rpm on the rev guage, i have taken the idle control valve and airflow meter off and giving them a good clean with carb cleaner but it still idles the same, ive checked for broken wires and they all seem fine, so my question is what could be causing it to idle high, and is there anyway of checking the bits to make sure i replace the faulty bits and not end up changing things on a trail and error basis ?
cheers
Old Jun 13, 2011 | 06:11 PM
Northants Ford Fan
anyone ?
Old Jun 27, 2011 | 10:39 AM
paulyzetec's Avatar
paulyzetec
hi mate have you check the light coloured plug under the power steering pump, theres two wires going into it, if one has snaped then thats the reason you have a bad idle. i have had the same problems with mk5 fiesta zetec engines.
Old Jul 3, 2011 | 03:29 PM
Northants Ford Fan
hi i have already cheked the wiring on the powers steering pump all is fine, the only other thing that happens occasionaly is when you dip the clutch the engine revs dont drop that quickly or go up a little then drop.
Old Jul 3, 2011 | 03:36 PM
RichieST's Avatar
RichieST
Could be a vacuum leak. Get some carb cleaner or easy start etc and spray it over inlet manifold gasket, vacuum lines etc. When the idle speed changes you've found your leak.
Old Jul 5, 2011 | 02:54 PM
Northants Ford Fan
Ive tried this on all the vacume hoses, the only thing that brings the revs down to 1000rpm is banging the aircon on, but it still revs high when you put your foot on the clutch at junctions.
Old Jul 5, 2011 | 03:53 PM
RichieST's Avatar
RichieST
If it were me I would be looking at replacing the idle control valve next, they are incredibly sensitive and often fail. There are only a couple of different ones across the entire Ford range so if you know someone with a fiesta / focus etc then try swapping them over as long as the part numbers are the same.
Old Jul 9, 2011 | 04:42 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
check the throttle plate return springs arent worn and it holds the throttle plate fully closed.
Old Jul 15, 2011 | 10:32 PM
siddleg's Avatar
siddleg
mine is the same mate then i changed the TPS and all was well for a month or so and now its doing it again been plugged in but nothings coming up
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
fordrallycar
Sep 30, 2015 07:57 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
