Ford Puma Discuss the Ford Puma here!
Puma abs fault
Old Jun 12, 2011 | 12:54 PM
ARLESLIE's Avatar
ARLESLIE
Question Puma abs fault
I have a 2001 Puma Thunder and the ABS / Anti skid warning light has come on. This was preceded by an brief intermittent whirring sound coming from, I presume, the brakes when driving along normally. That sound has now stopped but the ABS warning light stay on. Has anyone any idea what the likely cause is and what the solution is to fixing it. Thanks.
Old Jun 12, 2011 | 01:05 PM
rallycross's Avatar
rallycross
abs sensor they are available from motor factors for Ł45, Ford will charge you Ł110 for the same part.
Old Aug 24, 2011 | 08:11 PM
russ rs's Avatar
russ rs
i had same problem on mrs when front brakes
tankybaby66
Feb 6, 2016 02:24 PM
youngben
Sep 27, 2015 09:37 PM
