Ap water cooled front brakes question
Old Jun 11, 2011 | 08:21 PM
pig's Avatar
pig
Default Ap water cooled front brakes question
Right I'm running water cooled ap front brakes on my space frame mk2 escort, these where on the car when I brought it but the water cooling was not used.any people use water cooled brakes on there cars? How is the water side piped in?do you go into the cars normal radiator? Or use a separate radiator,pump,header tank etc.thanks inadvance guys
Old Jun 11, 2011 | 09:45 PM
Fast Guy's Avatar
Fast Guy
Don't water cooled brakes just spray a mist onto the brakes, so it's not a closed system with a radiator like engine cooling. I've always assumed it will just be a reservoir and a pump. Hands up though, I do know nothing about these set ups so could be completey wrong. It's just what I assumed from watching truck racing on the telly a few years back.
Old Jun 11, 2011 | 10:29 PM
zippyobrien's Avatar
zippyobrien
Use a charge cooler setup? Keep it seperate from the engine coolant I would have thought
Old Jun 11, 2011 | 10:43 PM
pig's Avatar
pig
Cheers fellas,be handy to hear from someone running these type of brakes tho tbh.car goes for cooler and rad etc to spec-r soon and if it needs a stand only system I will get it made while there.thanks for your replys tho.
Anyone else shed any light please?
Old Jun 12, 2011 | 05:57 AM
Jon(M600BHP)'s Avatar
Jon(M600BHP)
Speak to Mike Rainbird mate,
He has watercooled aps but he will probably tell you theres no point running water to them
Old Jun 12, 2011 | 06:33 AM
Mr.T's Avatar
Mr.T
i know that race trucks use them. But the just spray a mist of water on the brakes or something like that. I do know its not a closed system. For them anyway
Old Jun 12, 2011 | 06:37 AM
Mr.T's Avatar
Mr.T
http://www.honda-tech.com/showthread.php?t=1481342
found this. Google
Old Jun 12, 2011 | 07:30 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Originally Posted by Mr.T
but half way down the thread the guy gets the piss ripped out of him because he's apparently put the discs on the wrong way around and the calipers aren't titanium and the pads need to be seeing 1000 degrees to work at their optimum
Old Jun 12, 2011 | 04:43 PM
pig's Avatar
pig
cheers fellas,anyone else any thoughts please
Old Jun 12, 2011 | 07:09 PM
Jon(M600BHP)
if there like my old ones the water take off is at the rear of caliper
Old Jun 12, 2011 | 10:04 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Learn to read dojj. No one even says those first 2 things, and the 3rd thing, he gets shot down by the guy who was responsable for the water cooling/brakes on those cars.
Old Jun 12, 2011 | 11:18 PM
Marvin_hagler_'s Avatar
Marvin_hagler_
Marvelous Marv
ford motorsport used watercooled 4 pot ap's on the 4dr sierra 4x4's man
Old Jun 13, 2011 | 07:02 AM
M K's Avatar
M K
On the group a cars they used a headlamp washer pump that was activated via the brake light switch so the spray activated every time you press the brake,
This was not a closed system, just fed from a water tank on the grp a cars and from the iss tank on the wr cars (if they run wc)
The Grp a manual states:
"Water cooling is recommended for the front brake calipers on tarmac and rear brake calipers on gravel"
"The caliper pipes are made from steel 'bundy' tube with the end brazed and a small spray hole drilled"
Hope that helps you a bit,
Thanks
Marc
Old Jun 13, 2011 | 12:48 PM
wayne thomas's Avatar
wayne thomas
I used to run some on a Manta400 rally car, It was a closed loop system, the pump(bespoke & expensive) was switched from inside the car and only utilised when conditions required. To help keep the costs down we used a rad from a Yamaha DT175 enduro type bike, which came from a bike breakers.
Old Jun 13, 2011 | 01:15 PM
timrud's Avatar
timrud
How did you run a closed loop system? Unless all it did was to cool the calipers?
If it was like truck racing water cooler brakes then as said above, its just a mist for the discs to cool.
Old Jun 13, 2011 | 01:17 PM
wayne thomas
It just cooled the calipers.
Old Jun 13, 2011 | 01:25 PM
Gibbo87's Avatar
Gibbo87
heres another thread
https://passionford.com/forum/genera...he-brakes.html
Old Jun 13, 2011 | 01:44 PM
wayne thomas
Originally Posted by Gibbo87
The calipers pictured in that thread are the same as the ones I ran.
Old Jun 13, 2011 | 02:17 PM
timrud's Avatar
timrud
Nice one
Did it make much difference?
Old Jun 13, 2011 | 03:30 PM
Marvin_hagler_
Marvelous Marv
Nice one
ever seen a powerfull hefty rally car finish a stage with the brakes on fire man ? it made a huge difference but then so did 6pots then 8 pots
Old Jun 13, 2011 | 04:04 PM
wayne thomas
Nice one
A huge difference, we got the calipers at the right money too, so it was a real result
original
Jan 30, 2022 08:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
C2 MAK
Aug 20, 2015 09:46 PM
Aug 19, 2015 06:25 PM
Aug 10, 2015 12:08 PM
