General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Cheers folks, sounds like a job when the oil is next changed then
If you are using the sump plug adaptor, you can do it without changing the oil - Just make sure it's not hot, and whip it out and then put in the new adapter with the sensor already fitted. Use a clean bowl and you could even put the small amount of oil you loose back in the engine
or don't be pikey and top it up with fresh oil
Go through the trouble of having to dispose of the leaked oil or put it back in the engine - and save money? Not a hard choice
I really like that place to hold small things under the radio
Being a non smoker, i use the ashtray for that!
My ashtray is full of turbo heat-shield mounting pieces Must put those in place at last...
I don't know if you get those in UK but under the radio I keep the small print-outs I get each time I pay for parking in the city and all those call-girls adverts I get behind wipers (seen those in London phone booths - we get those behind wipers, lots of them)
