Clutch Problem On Esc Cos???
Old Feb 10, 2005 | 10:48 AM
FletchCos's Avatar
FletchCos
Default Clutch Problem On Esc Cos???
Last night I pulled away from a set of lights, put me foot down in 1st, went to change to 2nd and the clutch pedal became suddenly very stiff and she didn't wanna go anywhere! She now slips if you give it too much throttle and the pedal takes alot of effort to move and just bounces back into place forcing ya foot off the pedal!
Any ideas what this could be? Ive only just put the box back in, but it looks like she's coming out again this weekend
Its an Alcon 6 paddle clutch thats only done around 600miles
Old Feb 10, 2005 | 10:50 AM
Spiky's Avatar
Spiky
racket knackered????
Old Feb 10, 2005 | 10:51 AM
cossiechris's Avatar
cossiechris
Fletch, there's a good chance the slef-adjusting mechanism has stuck on oneof the ratchet teeth. Common problem mate
Old Feb 10, 2005 | 10:52 AM
RichardPON's Avatar
RichardPON
Sounds like you've effectively welded the cover to the plate.
I've had something similar - a few jump starts in gear freed it up.
The onl other thing is check that the clutch cable hasn't melted by the turbo...........
Old Feb 10, 2005 | 11:04 AM
FletchCos's Avatar
FletchCos
Thanks for the ideas...
Ive just pulled the pedal up towards the drivers seat and heard a click! Now the pedal seems free (Not as stiff), but I can hear some sort of spring squeeking?? Possibly the fingers on the clutch plate? The cable feels "Lumpy" if that makes sense?
Old Feb 10, 2005 | 12:06 PM
FletchCos's Avatar
FletchCos
Well Ive just taken her up the road and she's seems to drive fine now Only thing is when I put my foot on/off the clutch it sounds like the clutch plate or release bearing is squeeking! So gonna change the cable and see if that makes a difference, if not box will have to come out (Again) and see whats going on in there...
Thanks for the suggestions
Old Feb 10, 2005 | 12:13 PM
CraigN's Avatar
CraigN
do you have a paddle clutch ? mine squeeks since i fitted the alcon clutch
Old Feb 10, 2005 | 12:19 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Steve,
As I explained the OE ratchet isn't really up to much and really needs changing for a hydraulic one. You will always have this problem when do fast get-a-ways, unless you change it, so just avoid doing launches or fit the hydraulic conversion kit - job done.
Old Feb 10, 2005 | 06:15 PM
cossiechris
Steve,
Mike, do you do the hydraulic conversion kits ? If so, how much mate ?
Thanks
Chris
Old Feb 11, 2005 | 08:13 AM
FletchCos's Avatar
FletchCos
Cariag, yep an Alcon 6 paddle...
Mike, gonna change the ratchet for another standard one next week at some point... Will stop doing silly launches now How much is the hydraulic one fitted?
Old Feb 11, 2005 | 08:23 AM
Mike Rainbird
Caraholic
Click on my website for supply only prices...
Fitting is not cheap, however if combined with a clutch change - basically the clutch is done for free - the whole lot is then £600-700 (drive-train type dependent - 2wd is actually more expensive as the bell-housing needs modifiying).
Old Feb 11, 2005 | 08:24 AM
cossiechris
Old Feb 11, 2005 | 08:34 AM
FletchCos's Avatar
FletchCos
Cheers Mike, will look into it
yatta
May 21, 2016 10:31 PM
BigD.
Alloy wheels and ICE for sale
Sep 16, 2015 03:08 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
