Air con diagram Focus Mk 1
Old Jun 3, 2011 | 10:09 PM
EricRS's Avatar
EricRS
Default Air con diagram Focus Mk 1
As per above lads.
With it been really hot today I tried to use the air con on the car for the first time and its not turning on. The light on the centre console comes on but nothing happens. No rise in revs no cold air.
So what I've done so far:
1. Refill the gas in the system.
2. Check the fuse in the glove box. It was fine.
3. Check the fuse under the bonnet. That to was fine.
4. Check the relay under the bonnet. It should click when the air con gets turned on at the centre console, nothing happened. I replace the relay with another working one. Still nothing. So no power passing through it.
Don't want to even think about looking at the wiring with out a diagram.
Anyone got one they can PM or email me or know where I can download one?
Old Jun 4, 2011 | 08:25 PM
mercury grey minter's Avatar
mercury grey minter
I'd check the clutch is engaging on the air con pump
Old Jun 5, 2011 | 07:43 AM
EricRS's Avatar
EricRS
Is that the weight seen on the outside of the pump. It hasn't moved at all. I thought that would be because it wasn't getting power. Hence looking for a wiring diagram. What you think?
I was in ford the other day and mensioned it to the parts lads and their faces all said money os if I can sort myself I'd rather have a go.
Old Jun 5, 2011 | 12:36 PM
cossiedevil's Avatar
cossiedevil
I have the wiring diagram eric mate but it wont let me copy to send it on to ya going too see what i can do.
Old Jun 5, 2011 | 06:56 PM
EricRS's Avatar
EricRS
Could you print it out and post it to my. Any word on the VRT thing yet.
I had a look at the block connector at the clutch there today and its not in great shape. So could be the problem. I'll get my mate to check it in a day or so to see if it has a current even going through it. There seems to be a split in the live wire to so hopefully its an easy fix.
Old Jun 5, 2011 | 08:37 PM
cossiedevil
Can you pm you email to me eric
Old Jun 5, 2011 | 08:38 PM
cossiedevil
Can you pm your email to me eric
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
ward1174
Sep 12, 2015 03:34 AM
markk
Sep 9, 2015 08:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
