turbo ex housing question
Old Feb 9, 2005 | 08:27 PM
wimwerf's Avatar
wimwerf
Default turbo ex housing question
Hi all,
i dont understand something....if im driving with a t-3.48 and i put a t-34.63 on...i have more lag....
but i see some big bhp cars with fooking big turbo's and 1.15 ex housing...but they say it has same lag as a t-34....how is that possible....
soemone can explain.....
Old Feb 9, 2005 | 08:31 PM
Red16's Avatar
Red16
im no expert but a lot still depends on engine spec
Old Feb 9, 2005 | 08:32 PM
wimwerf's Avatar
wimwerf
yeah but if you see a t-4 make boost about 4k rpm.....
Old Feb 10, 2005 | 03:01 PM
wimwerf's Avatar
wimwerf
any expert can explain....
Old Feb 10, 2005 | 03:03 PM
CabrioTurbo's Avatar
CabrioTurbo
it is to do with mapping and choice of cams and general head spec also, along with other factors such as compression ratio..
there are many things that can be done to 'map out' the effects of a HOOOGE turbo.
Old Feb 10, 2005 | 03:04 PM
Azrael's Avatar
Azrael
It's not only exhaust housings, but wheels geometry, weight, bearings, special mapping to fight lag, also compressor wheel has impact..
Old Feb 10, 2005 | 03:16 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Its mainly down to much newer technology wheels in the turbos (well all parts really, wheels, housings, beaings, shafts, etc).
Its a joke really=
Whats the difference between a GT30 and a RS500 T4?
About 30 years and a Scania Truck
Old Feb 10, 2005 | 03:23 PM
Porkie's Avatar
Porkie
Default Re: turbo ex housing question
They could also be talking out of their arses! don't forget that is also a realistic reason mate
Old Feb 10, 2005 | 03:26 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
yea, i think total bullshit is a big part of it, lol.
the need for these huge housings on a engine around 2litre is quite bizzare anyhow...
Old Feb 10, 2005 | 03:38 PM
PF Ben's Avatar
PF Ben
it's all about getting the right combination of parts in the turbo for the engine. modern management also helps response off boost exponentially. On a HUGE RS200 turbo for example it's possible to be at a full 2-bar of boost by under 4000rpm keeping these things in mind
Ben
Old Feb 10, 2005 | 04:38 PM
ImaRacing 700's Avatar
ImaRacing 700
Basically because the huge turbos now use roller bearing technology which help spin turbo up quicker.
Old Feb 10, 2005 | 04:40 PM
Karl's Avatar
Karl
Norris Motorsport
LOL at the horse shit on this post!!
Old Feb 10, 2005 | 04:47 PM
wilky's Avatar
wilky
Default 620 ti sherpa
hi the bigger a/r the longer spool up time but
more flow at the top of your rpm.the bigger the
a/r the more area the longer it take's fill up with
exhaust gas but it should hold boost to the end of
the rpm[not unless your acturator is weak]
something like that
Old Feb 10, 2005 | 04:51 PM
the strut brace's Avatar
the strut brace
there always is when phil has posted , hey karl, did you know that he's builing a 650plus engine he may have mentioned it once or twice
cheers carl
Old Feb 10, 2005 | 04:53 PM
Karl's Avatar
Karl
Norris Motorsport
Is he really, I never knew? Do you think he'll be up for a race when hes' finished ?
Old Feb 10, 2005 | 04:56 PM
PF Ben's Avatar
PF Ben
I do trust you're not referring to my comments Karl?
Ben
Old Feb 10, 2005 | 04:57 PM
the strut brace
the muppet will NEVER be finished, long live the haters its taken him about a year to pick a turbo, only another 100 or so parts to go and it will be up and running and then you'll be scared
Old Feb 10, 2005 | 05:05 PM
ImaRacing 700
Er i first mentioned this build at the end of December 04...its now early FEB...a very funny year It will be done as soon as all the parts arrive as SPEC is now final.
Do you really think this is all bollocks or are you just trying to impress the boys?
Old Feb 10, 2005 | 05:12 PM
the strut brace
pmsl , no i believe your doing it phil, imo it would be better if you told people what your doing instead of this vale of secrecy and shite, hat off to you mate if your doing this by yourself and we are genuinly interested in your progress, try being one of the lads again instead of isolating yourself by keeping everyone in the dark, nobody is going to copy you , it just makes for more intersting reading if your reporting summit worth reading instead of repeating yourself about the same stuff but just saying it in a different way
anyway , back to normal............stop talking shite, i'm no fudge pusher
Old Feb 10, 2005 | 05:49 PM
rapidcossie's Avatar
rapidcossie
funny how karl says its all shit but doesnt explain it himself?
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
jaimesdna
Aug 25, 2015 06:59 AM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
