cossie running fault after i broke diff???????
hello boys & girls, i have a random running fault with my saff cossie.
its been running spot on for ages & last sunday i gave it large it 1st & quickshifted it into 2nd & BANG!!!!!!!!!!!!!
car rolled to a stop & the result was a broken diff but....................
when the car rolled to a stop i noticed it was running rough asif it was on 3 cylinders
car was towed to lock up & new diff fitted today, started car uo for 1st time since & its running rough still.
i tried another set of plugs in it & no joy
heres what it does:
runs rough on idle but assoon as throttle touched its mint & to drive it you wouldnt know there was a fault till its back on idel again.
when car runing rough on idle if u gove it 2-3 large revs it will the idel fine
or
if driving it & give it large then pull up it will idel fine
i did notice the engine does have a noisey tappet now & was thinking it could be that collapsed on idel (not enough oil pressure for it) causeing the valve not to be fully open when when revved & oil prerssure rises its all good
any other idears??????????????????
whn u pull a ht lead off 1 at a time the all make a differnce & its getting fuel & spark to all 4 cylinders
cheers
heres what it does:
or
cheers
I would check the CO, if too weak it will always "attack" the weakest cylinder first, might just need richening up a bit.
Other fave areas are did the revs go sky high enough to bend a valve ?
nah never valve bounced it
my 1st option was valve but if it was a valve it would allways idle rough
2day- get in car idleing rough, drive 2 mines perfect but everytime i stop idle rough, stop turnn it off.
start up 2 min later idel perfect & runs perfect
off-on, runs perfect
off-on runs perfect doe this 3/4 times
drove to dinner runing perfect, on way back stop at traffic lights & its running rough again
5/6 hrs later i go home & alls perfect again
valve cant be intermitant fault
my thoughts now are are:
may its a dodgy plug????
or
maybe lifter not opening vave on idle????? & when revved oil pressure rises & its ok???
& every now & then its ok??????
more inspection tomorrow
want 2 get it sorted so can take it classic ford sunday & run it up strip
or
It could be a lazy tappet, but you'd normally hear it, as one being distinctly noisy compared with the rest, they can be taken apart and cleaned out easy though, I did on mine(just rebuilt engine after 200K), mine even when left 2 weeks is 100% silent on start up, not even the faintest hint of rattle, the tappets have done around 100K.
after your recent test, when you say running rough, do you mean 3 cyclinders?
if so, it could be a wiring fault to injectors, notorious common problem, especially on old looms
tried dizzy cap, rota arm, leads & plugs & still no joy
tried another fpr as had this problem before & was that but still no joy
looks like the heads cimeing off when i get back from offshore for further inspection!
does seem like a valve problem when its running rough but dont get how it can be when the next minute its running mint??
runs on 4 cylinders but badly on idel (sounds like its on 3)
CabrioTurbo
Aug 1, 2015 11:04 AM
