MAP sensor signal wire
Does anyone know which wire of the MAP sensor gives the actual signal to the ECU on a Cosworth 4x4? I'm thinking it will probably be the brown/green wire on pin 11 of the ECU, but I'm not sure.
And can someone also tell me which wire carries the tacho signal at the ECU? The car has the MSD wasted spark conversion installed.
Thanks!
But if the range is from 17 to 308 kPa and 0.25V to 4.75V, the linear range would be (308-17)/(4.75-4.25) = 64.67 kPa/V
I don't know where you got your linear value from?
Edited: Ah, I see. Your linear rate should be 0.01546 V/kPa.
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
