ABS block brake pipe?
May 27, 2011 | 07:43 PM
As title what size and thread type are the brake pipes in the ABS block on a 2wd Cosworth?
Cheers in advance
May 28, 2011 | 06:46 PM
May 28, 2011 | 06:55 PM
Quote:
Originally Posted by
BRAMMER
Anyone?
I bought a load what one do you need ? If I have one you can have it.
Cheers Ade
May 28, 2011 | 07:05 PM
Ade what i'm actually doing is changing the pipes for braided hose and banjo fitting setup to clear my new inlet manifold
May 28, 2011 | 07:15 PM
I will look on the receipts for the two sizes then.
Ade
May 28, 2011 | 07:26 PM
Ok found them, they are M 10 x 1mm and M 12 x 1mm.
Ade
May 28, 2011 | 08:22 PM
Ade500
Ade
2 outer M10 and inner M12?
May 28, 2011 | 09:17 PM
May 28, 2011 | 11:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
coscor86
Sep 20, 2015 01:21 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
