Paint
Old May 27, 2011 | 07:42 PM
rudkinrst's Avatar
rudkinrst
Default Paint
Hi guys I've just recently bought a mercury grey S2. Around the sunroof is just starting to bubble slightly and I'd like to get it sorted before it gets worse. Was just wondering if anybody could give me a rough idea on what it would cost to paint roof and front bumper.
Thanks
Old May 27, 2011 | 07:47 PM
stevealien's Avatar
stevealien
10 Year Member
prob 3 or 4 ish mate
Old May 27, 2011 | 10:23 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Would be a fair amount,as the sunroof area is a pain in the arse.If not done correctly,the rust,bubbling will be back in no time.Will need the roof lining taken off and sunroof taken out to do the job correctly.As i'm currently having mine done...
Old May 28, 2011 | 01:12 PM
muz's Avatar
muz
Wye Valley Hardcore
If theres rust coming through on top be prepared for lots of rust underneath. Rather than get it repaired I'd put the money into a carbon roof panel.
Old May 28, 2011 | 01:33 PM
phil_focus's Avatar
phil_focus
as muz says really. when rust shown around the sunroof on erst's its usually because the pannel has rusted through from undernieth. need to take the headlining and sunroof out to see how much damage is done.
from what i've read on here the easiest solution is to cut the pannel out and fit a carbon roof. if you don't like the look then get it painted.
Old May 28, 2011 | 03:01 PM
rudkinrst's Avatar
rudkinrst
Surely it wud cost more to have a carbon skin fitted than to have the roof painted
Old May 28, 2011 | 03:03 PM
muz's Avatar
muz
Wye Valley Hardcore
Not if you're repairing and repainting the roof every 6 months though, mate.
Old May 28, 2011 | 03:12 PM
phil_focus's Avatar
phil_focus
it won't be surface rust though. the pannel will be rotten through. i bet if you wire brush it you will find holes and you can't paint a rusty hole. then when you remove the headlining and sunroof and have a look insude it will be rotten needing a new pannel.
i think with the carbon roof you just cut the roof out leaving a lip all the way round and then bond the carbon roof on, fairly easy. you won;t even have to get it painted straight away being carbon so you could do the "repair" and then get it painted some time in the future if you wish. could always use it as a theme for the car.
Old May 28, 2011 | 04:49 PM
luke19790_3's Avatar
luke19790_3
just put a carbon roof on mine, it's worth the money.
my old roof looked ok from the outside but under the headlining
not the best picture
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
