What size hose for T34 turbo?
Old May 26, 2011 | 05:25 PM
g10ens's Avatar
g10ens
Default What size hose for T34 turbo?
At the moment I have a standard T3 turbo and standard original air filter box linked by a hose of 60mm inside diameter. In the future i will upgrade to a T34 turbo (but only once my T3 is totally knackered) will the 60mm hose that I have be suitable for a T34 or will I require a bigger inside diameter hose?
The reason I ask is that I want to buy a cone filter to use on my T3 but I don't want to find out that the neck of it will be too small if I have to fit a larger hose when I eventually get a T34, if that's the case I will just stick with the original air box until I get the T34.
Old May 26, 2011 | 05:55 PM
mechanic28's Avatar
mechanic28
70mm for a t34 bud
Old May 26, 2011 | 06:15 PM
g10ens's Avatar
g10ens
Thanks, will stick with what I've got for now then. Will I also need to change the hose from the turbo to the intercooler for a larger one?
Old May 26, 2011 | 06:32 PM
mechanic28's Avatar
mechanic28
no mate that stays the same on t34
Old May 26, 2011 | 06:37 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u can make the t3 hose fit..............just shove the fucker on lol
Old May 28, 2011 | 02:09 AM
dazzle740's Avatar
dazzle740
Buy your large cone filter now and a hose suitable for your future T34 then fit it to your T3 by cutting a small band off your T3 hose slid that onto your turbo then slide the T34 hose over the top then your clamp. Job done plus your ready for when you get your T34.
Matt Baxter
Sep 16, 2015 08:30 PM
borboyous
Aug 22, 2015 11:17 AM
Dicko&Vacant
Aug 21, 2015 05:59 PM
marky_g
Aug 3, 2015 04:45 PM
