AMAL valve
Hi all. Are the AMAL valves the same on the RS Turbo as a 2wd cossie?
I suspect mine not to be working and have been offered a RS turbo one cheap. Looks the same but are they?
cheeRS
cheeRS
saff is working!!!...atm
amal valve aint a complicated thing......does it click when u turn ur ignition on......other than that u can take it apart and remove the spring & weight from inside and then it just runs fully open......mine's been like this for years
Martin
Pete i dont know it all..!...but i prefer a amal valve that works...If yours works fine without and your happy mate...Well thats what counts...
It doesn't matter a shit who says your right, be it the often arse licked stu or whoever, it's not a question of right or wrong, it's a question of you have what you want and let others have what they want.
I'm not arguing, frankly if your engine goes bang that's your problem not mine, but if you don't want opinions on a PUBLIC FORUM, try not inviting them, by posting.
The reason why other people who may have the same opinion as myself don't post is generally they are too busy arse licking, and daren't disagree with anyone established.
tabs u were the one coming on the thread calling people stupid,so it does get my back up when i know this method eliminates a daft electrical/wiring fault......so i aint fucking arguing about it either...........xx
