Longer wheels studs (group a?)
Looking to put some on my car, what length to people generally go for?
Wana fit them along with the open ended nuts for when i run my flat faced comps.
what are people using or used in the past?
cheers, pete
cheers, pete
I got mine from a local performance parts place but their made by eibach, they were part of a kit for a hubcentric spacer kit I used to run. I'd recommend eBay or speedshack for better prices though, I can't remember what length they were but I'm sure it's M10x1.5 thread.
standard ford studs are M12 x 1.5 and are readily available on abay in various lengths
The grp a studs are M14 x 1.5 and use a collar/sleeve on the inner part of the stud
Hope that helps
Marc
Hope that helps
Marc
NO mate, M12 is the standard ford wheel stud diameter and 1.5 is the pitch (distance between teeth on the stud)
Hence grp a studs are M14 which is a size up from standard so they are beeffier/stronger to withstand the greater abuse a rally car gets
hi all,
the ones on my old car were group a
i've just posted this as its just been seen again, check the wheels, they where 8x17 et20 and i got the studs from ears motorsport
https://passionford.com/forum/ford-s...-cosworth.html
cheers
cheers
mike elsome
Sep 14, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
