Hi what bhp should i expect from this setup
Old May 24, 2011 | 09:04 PM
djvu's Avatar
djvu
Default Hi what bhp should i expect from this setup
Just curious what bhp and what boost do you think is ok for this set up
K&n filter
2 stage boost control ( amal)
chipped ecu
gas flow polish n ported head
uprated fuel pressure regulator
turbo reworked to phase 3 (hybrid garret )
hi lift 285 t2 cam antipump lifters ect ect
full stainless 2.5" exhaust
pace intercooler
pace rad+ swirl pot
standard ngk bcr8es spark plug
Its running 7psi low boost 15 - 18 psi high boost atm.....
Old May 24, 2011 | 09:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The MFI fuelling is your limiting factor, followed by your rods, anything from 200-240bhp if the metering unit is working well.
russ rs's Avatar
russ rs
around 200-210 if still on mfi
Old May 24, 2011 | 09:46 PM
J1mbo's Avatar
J1mbo
B1mbo
At 18 psi 210 would be my estimate
Old May 24, 2011 | 10:05 PM
djvu's Avatar
djvu
How do i tell the difference by mfi and efi by looking, the car is xr3i but had a rs lump donnated and modified , what kinda results would i get from efi ...
Old May 25, 2011 | 12:58 AM
DanRSturbo's Avatar
DanRSturbo
I thought Pace intercoolers couldn't go much past the 190 horses barrier due to the ACT's getting too high.
Old May 25, 2011 | 09:18 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If you have a fuel metering unit then your MFI if you dont and have a inlet manifold with EFI stamped on it and a fuel rail with electronic injectors your EFI.
With your spec and EFI you could make 260-280bhp but your rods will bend/break at over 240bhp if your not careful!
Only if it's a DC IC, if it's a full front mount then it's fine.
Old May 25, 2011 | 07:01 PM
djvu's Avatar
djvu
Old May 25, 2011 | 07:02 PM
djvu's Avatar
djvu
cheers for a butcher this is my engine, No efi written on it so i assume its mfi?
Old May 25, 2011 | 07:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
MFI.......
Old May 25, 2011 | 07:04 PM
djvu's Avatar
djvu
karlos my pace is front mounted jobby , Would i gain more buying a grs?
mr_joe0606's Avatar
mr_joe0606
looks like your on mfi mate 210bhp at a push before you will melt something. good spec by the way any more pics
Old May 25, 2011 | 07:10 PM
djvu's Avatar
djvu
cheers for that, It last got rolling roaded about 8000 miles ago and it sat at 203bhp 207 lbs/ft peak torque at 5446rpm previous owner took it down to power engineering, I dont think its pulling that atm
Old May 25, 2011 | 07:12 PM
djvu's Avatar
djvu
Old May 25, 2011 | 07:13 PM
djvu's Avatar
djvu
Old May 25, 2011 | 07:15 PM
djvu's Avatar
djvu
djvu's Avatar
djvu
djvu's Avatar
djvu
mr_joe0606's Avatar
mr_joe0606
oooo you will be getting high act with that intercooler mate.
Old May 25, 2011 | 07:18 PM
djvu's Avatar
djvu
yer so ive been reading about the high acts with these intercoolers , To be fair i wanna replace it with a grs , Keep the acts down and get rid of that front grill mesh]
Old May 25, 2011 | 07:23 PM
mr_joe0606's Avatar
mr_joe0606
if you cant find a second hand 1 this is a very good cheaper option
http://www.autospecialists.co.uk/Pol...oduct-662.html
i have it on mine
Old May 25, 2011 | 08:04 PM
djvu's Avatar
djvu
yer will be looking into it seriously
do u know what this is at all
djvu's Avatar
djvu
red pipe going onto the inlet
Old May 25, 2011 | 08:06 PM
Rob_DOHC's Avatar
Rob_DOHC
Mate, a NEW grs is cheaper than that
http://www.grsmotorsport.co.uk/ersts2intercoolers.html
Rob,
Rob_DOHC's Avatar
Rob_DOHC
Cold start injector
Old May 25, 2011 | 08:59 PM
djvu's Avatar
djvu
cheers rob, I take it thats the one to unplug when its a lumpy awkward start?
I just remeber seeing someone having rough starting issues and was told to unplug n see
Ya right on that grs its cheaper!
Old May 25, 2011 | 09:25 PM
Rob_DOHC's Avatar
Rob_DOHC
Hiya mate,
Tbh, if the injection system is working properly it should be easy and smooth to start with the injector plugged in. Unplugging it is really just masking a problem. Your best bet is to have the system checked out and set up by a pro, in the long run it will save you lots of money and tears.
A badly set up car will ruin your engine in no time.
Good luck
Old May 26, 2011 | 07:27 AM
mr_joe0606's Avatar
mr_joe0606
how much are the fans they supply with it . and how much is the single pass intercooler? to be honest when i whet on the auto spec web site i though they were cheaper than that my bad lol
Old May 26, 2011 | 07:36 AM
Rob_DOHC's Avatar
Rob_DOHC
True Joe, maybe the GRS doesn't come with fans. But either way, its a great piece of kit. In the end i bought a Radtec but the GRS was a close AND cheaper second.
Rob,
Old May 26, 2011 | 10:06 AM
DanRSturbo's Avatar
DanRSturbo
Joe what sort of Acts do you see with that setup ? Do both fans kick in together ?
Old May 26, 2011 | 10:33 AM
djvu's Avatar
djvu
Cheers rob im getting it set up soon just doing a few changes before hand
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
