Wots the most psi a standard t2 actuator run..
Old May 24, 2011 | 01:32 PM
pauldonachyrs's Avatar
pauldonachyrs
Default Wots the most psi a standard t2 actuator run..
Wots the most psi a standard t2 turbo and actuator run it's running 165bhp superchips chip pace intercooler and a piper cam, been told could run 10psi that correct???
Old May 24, 2011 | 01:33 PM
pauldonachyrs
Want to push 12psi out it if possible
Old May 24, 2011 | 07:23 PM
jayRS's Avatar
jayRS
a T2 will do about 18psi but it wont last long, the safe limit is max of 15psi really, but the std actuator wont allow that much, your need a upraded one.
myself, i wouldnt advise more than about 12 psi on a std T2 and thats what i run on a 195 set up
Old May 24, 2011 | 08:30 PM
pauldonachyrs
il just be running stage 1 12 psi will do me on std turbo and actuator
Old May 24, 2011 | 08:32 PM
pauldonachyrs
now anyone selling -31 actuator
Old May 24, 2011 | 09:58 PM
jayRS's Avatar
jayRS
your be alright then with 12, this is, provided your turo nots on its last legs now.
this is the actuator i have on my car, ive had it on there for years now, prob getting on for 7/8 years, still going strong and cant fault it one bit
http://cgi.ebay.co.uk/FORGE-ADJUSTAB...item20ad27053b
Old May 25, 2011 | 11:10 AM
pauldonachyrs
ye seen then the other day wen looking threw ebay...
Old May 25, 2011 | 11:19 AM
jayRS's Avatar
jayRS
there good mate, ive not had to touch mine, but unlike a -31 sealed unit, you can strip them down and repalace the spring and diaphram.
or if you want a stronger spring , order one and fit it,
Old May 26, 2011 | 12:02 PM
pauldonachyrs
ye might if i decide to go more power or no.
Old May 26, 2011 | 01:46 PM
jayRS's Avatar
jayRS
saves buying another complete unit then fella
steve.rst
Mar 15, 2016 08:01 AM
Cosnada
Jan 7, 2016 05:30 PM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
Marino
Sep 12, 2015 11:10 AM
